347 on dyno do not like timming advance...
v8_super
Post by v8_super » Sun Sep 27, 2009 11:12 am
I have my first time on Dyno yesterday, it runs ok but do not like more than 31 total timming advance
400hp-5962rpm(tranformed from rwhp /.75) at 31º and 390hp at 35º on 95 octane gas , litle lean .92 air/fuel lambda
406hp-5490rpm (tranformed from rwhp /.75) at 31º and 395hp at 35º on sugar cane Ethanol 100% (not e85) lean .93 lambda
Is this timming ok? Title lean air/fuel ratio could be the question?
It was very warm 96º F on gas test and 103º F on ethanol test.
I was expect 34 or 36º be better.
Thanks in advance.
347 sbf, 9.8 CR (very low for ethanol), afr 185, autolite 3923 plugs 0.39gap, mallory 6al/msd pro billet dist, comp xe 274 hidraulic, performer rpm airgap, 1 5/8 hedmam headers full exsaust summit chamber muflers. Power stearing pump, water pump and alternator w/out underdrive.
ProPower engines
Post by ProPower engines » Sun Sep 27, 2009 1:33 pm
I would have thought that with only that comp. ratio more 5timing would have helped.
Air density must have been low( less oxyegen) to allow more timing.
PFC1
Post by PFC1 » Sun Sep 27, 2009 1:44 pm
Done a gas Ford 408 couple years back, much higher compression than yours though. Had Roush heads. Did not like more than 28* total timing. And ran better with 27*.
Bret
Pullin' for Christ
hondo383
Post by hondo383 » Sun Sep 27, 2009 3:17 pm
I build very similar engines alot...sbf 331 0r 347 92 octane pump gas, 10:1 with a mahle flat top and 60259 edelbrock heads. And they all top out around 31-33* timing, 430 ish hp. seems like you are in the ballpark. you can only give it what it wants :D
xstfudonniex
Post by xstfudonniex » Mon Sep 28, 2009 2:00 am
PFC1 wrote:Done a gas Ford (406 I believe) s couple years back, much higher compression than yours though. Had Roush heads. Did not like more than 28* total timing. And ran better with 27*.
Bret
How much power did it make?
[img]http://i67.photobucket.com/albums/h291/downsideup09/DSCF2616-1.jpg[/img]
Procision-Auto
Post by Procision-Auto » Mon Sep 28, 2009 6:29 am
You're making some pretty good power through mufflers based on
the cubes, low compression and fuel.
There is likely some extra power hiding in the exhaust/intake tuning,
and mechanical settings (cam phase, lifter settings, etc.).
Don't be upset that your engine makes more power with less timing.
Look for ways to bump the power like altering the muffler placement/
secondary lengths, carb spacers/flow plates, and things of that nature.
Is this your intake air temp by chance?
PFC1
Post by PFC1 » Mon Sep 28, 2009 8:31 am
Bret
It was just shy of 600, circle track deal using the iron Roush heads... it really needed more head on it. But it did run very well in the car.
Bret
Pullin' for Christ
RCJ
Post by RCJ » Mon Sep 28, 2009 10:39 am
With the motor lean it will like a little less timing.That is one of the thing I do on the dyno,lean less timing vs richer more timing.The motor in our car now likes lean less timing.
CamKing
Post by CamKing » Mon Sep 28, 2009 10:50 am
I've seen a lot of fords running the "N" heads, and it's normal for them to run timing in the 30-32 range.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
d64falcon
Post by d64falcon » Tue Sep 29, 2009 12:29 am
CamKing wrote:I've seen a lot of fords running the "N" heads, and it's normal for them to run timing in the 30-32 range.
I just started using the N351 head. I started at 28* and am at 37*now. the reason i belive im so high is I have ressesed plug and using 110 fuel with 10.5:1.
Darrell
67 Mustang 3000# 310ci NA 10.17 130.5mph,1.36 60'
maxracesoftware
Re: 347 on dyno do not like timming advance...
Post by maxracesoftware » Tue Sep 29, 2009 1:38 am
v8_super wrote:I have my first time on Dyno yesterday, it runs ok but do not like more than 31 total timming advance
Thanks in advance.
the SBF Chamber likes a lot less BTDC timing than same cid/CR Chevy engines
27btdc to 32btdc range is mostly what i've seen .
Meaux Racing Heads
MaxRace Software
PipeMax v3.98   http://www.maxracesoftwares.com/forum/v ... f=14&t=249
v8_super
Post by v8_super » Tue Sep 29, 2009 6:50 am
Thank's guys
these are the dyno grafics
Ethanol:
95 octanes pump Gasoline
Feel free to make more coments about that... this will help me.
v8_super
Post by v8_super » Tue Sep 29, 2009 3:00 pm
One more question, are the original afr spring (1.45" 120Lbs seated, 11/32 valves, titaniun retainers 1.7 HS rockers) ok to rev 6000+ on my xe 274H ?
stevek
Post by stevek » Tue Sep 29, 2009 3:28 pm
PM Sent!
v8_super
Post by v8_super » Thu Oct 01, 2009 8:10 pm
I think my torque courve goes down quikly above 4K.....
need some advice on it!!!!!
