minimum rod side clearance
So side clearance would be greater than .007" I guess?bobqzzi wrote:Actually, I think at this point they are all piston guidedBaprace wrote:mmmitch588, Nascar engines run virtualy no vicosity oil weight so it pours like water or thinner I would not be surprised at all to see them run with .007 side clearance, not sure how small a crankpin diameter is allowed.
They are running some extremely tight bearing clearances now.Baprace wrote:mmmitch588, Nascar engines run virtualy no vicosity oil weight so it pours like water or thinner I would not be surprised at all to see them run with .007 side clearance, not sure how small a crankpin diameter is allowed.
Website is up and running
Machine shop tour
Monthly Specials
Machine shop tour
Monthly Specials
CNC BLOCKS wrote:They are running some extremely tight bearing clearances now.Baprace wrote:mmmitch588, Nascar engines run virtualy no vicosity oil weight so it pours like water or thinner I would not be surprised at all to see them run with .007 side clearance, not sure how small a crankpin diameter is allowed.
Nope
Just old std .0012 rods and .0015 mains.
3V Performance
" ENGINES WITH AN ATTITUDE "
980-222-7230
980-222-7230
SOME ... and not just the weak ones, either.
That sort of condition will require more than minimum side clearance. MINIMUM side clearance is based upon all the parts retaining their dimensional integrity.
I was told that a crank in an IHRA Pro Stock engine gets over .030" shorter when over 6500 RPM.
When you machine a crankshaftrmcomprandy wrote:SOME ... and not just the weak ones, either.
do you machine for MINIMUM or do you try and machine for NOMINAL??
Yes,I'm just messing with you.
LOL ... that's not such an "off the wall" question in this day and age. If the journals are not absolutely round with no chatter picked-up with an Arnold guage and all journals are not consistant I will return it untill I get a good one.
Crankshaft technicians used to hate me untill I found a good guy who has the same standards I have.
Performance Crankshaft, Inc - Detroit
