Valve reliefs in a BB Chevy, Yes or No
I searched for this topic with no luck, So I'm going to ask this question. I'm assembling a 454 2 bolt block, 0 deck, with a 4.280 bore. I have been thinking about adding valve reliefs on the block both intake & exhaust. I know this has been done before but I have never really heard of any real solid claims or gains. Has any body out their seen any solid gains with their engine on a dyno or increased in flow on a bench head stand. I have scribed the deck to match the chambers, and their is a obvious edge. I'm using a BB Chevy oval port true closed chamber head casting number 3872702. The heads have the 2.19 & 1.88 valves installed with major chamber un shrouding. The heads will be milled to at least .030, and no more than .060. When all done & said, I would like to see 9.5 compression ratio, no more than 10.5 with my flat top piston L 2377. So, I would like to hear all Good and Bad ideas on this topic.
Thanks for looking,
Thanks for looking,
Ron Miller
- Show Guest
I have done the chamfer in the top of the cylinder all my life. You only need to worry about the intake side, not the exhaust. I think it could be a very big deal on a serious engine, but your build is pretty mild, so it might be worth something like 10, maybe 15 HP- I do know on high HP engines ( 800-900 hp ) it can be worth 20 to 30 HP
JOE SHERMAN RACING
JOE SHERMAN RACING
MadBill,MadBill wrote:Just make sure they don't go as deep as the top ring's upper travel limit.
Thanks for the heads up ! I have that covered. I maid a simple tool with a 90 degree scribe. I set it - .030 from where the top ring will set at TDC.
Thanks Again for the reply,
Ron
P.S. Why do you call you self MadBill ??????? L.M.A.O.
Ron Miller
My (still) best friend when we first met 50-odd years ago lived on a farm near our cottage. Over time his dad noticed that come July each year, things would start going badly wrong with their peaceful rural life: Grass fires, explosions, calls from the cops about a pair of VW's terrorizing a local subdivision... Somehow he associated the mayhem with my arrival for the summer and came up with the "Mad Bill" moniker and it has stuck all these years..Ron Miller wrote:...P.S. Why do you call you self MadBill ??????? L.M.A.O.
I've seen blocks with just the intake side chamfered and some with both sides chamfered. Head gaskets often have a little bulge there too. Is it just a tiny bit more power to do the exhaust side, which is why some don't do it? Not worth the effort?bigjoe1 wrote:I have done the chamfer in the top of the cylinder all my life. You only need to worry about the intake side, not the exhaust. I think it could be a very big deal on a serious engine, but your build is pretty mild, so it might be worth something like 10, maybe 15 HP- I do know on high HP engines ( 800-900 hp ) it can be worth 20 to 30 HP
JOE SHERMAN RACING
Bryan
583 in 225" hardtail dragster
Northern Lights Raceway
Not to hijack, but how much power do you gentlemen think a head with a chamber 4.500" across with a 2.30" valve would give up on a 4.310" bore? I'm looking at a substantial ledge on the intake side of the chamber.
I'm helping a friend upgrade from a 496 to a 555 short block. The heads on his 496 seem to be a much better fit for the bigger 4.560" bore.
E85 racer and E85 carb builder
www.horsepowerinnovations.com
68 Camaro 427" E85 powered small block, 9.95 @ 133 mph best motor ET through the mufflers. 1.319 best sixty foot.
been wanting to ask that question myself. Great stuff...MadBill wrote:My (still) best friend when we first met 50-odd years ago lived on a farm near our cottage. Over time his dad noticed that come July each year, things would start going badly wrong with their peaceful rural life: Grass fires, explosions, calls from the cops about a pair of VW's terrorizing a local subdivision... Somehow he associated the mayhem with my arrival for the summer and came up with the "Mad Bill" moniker and it has stuck all these years..Ron Miller wrote:...P.S. Why do you call you self MadBill ??????? L.M.A.O.
My Profiler 320`s flowed 18 cfm less on a 4.31 bore vs. 4.5" They have 2.300 intake valve also. Probably looking at 35 hp.Eric68 wrote:Not to hijack, but how much power do you gentlemen think a head with a chamber 4.500" across with a 2.30" valve would give up on a 4.310" bore? I'm looking at a substantial ledge on the intake side of the chamber.
Galatians 2:20: I have been crucified with Christ; it is no longer I who live, but Christ lives in me; and the life which I now live in the flesh I live by faith in the Son of God, who loved me and gave Himself for me.
Re: Valve reliefs in a BB Chevy, Yes or No
A good thread and I did both valves on my Merlin cast-iron large ovals with 2.19"/1.88" valves back years ago. I do have a set of 8 Manley 2.300" valves for them but never put them in.
Re:
"do it right or do it right away"
http://www.motionmachineinc.com/
https://www.youtube.com/watch?v=ZgIZbveknDs
