What effect, if any, does severe angle milling have on rocker arm geometry? I know that you can adjust things with pushrod length or, in the case of pedestal mounts, shims but what does it do, if anything, to valve motion. It seems as though the angle between the pushrod and the rocker stud will change, as well as the angle between the pushrod and the valve. I know that the rocker ratio is designed into the rocker and can't change but if the angle between the pushrod and rocker changes then what? Will valve acceleration rates and max lift be the same? Is it more difficult to get a narrow, centralized wear pattern over the valve stem? Does it increase side loading on the valve guides?
Thanks
Angle Milling and Rocker Arm Geometry
