Why not?RevTheory wrote:I don't think you'd want to, would you?Erland Cox wrote: How do you get 15:1+ compression on a big bore short stroke P/S engine with an LSA under 112 degrees?
Erland
Erland
Erland
BINGO.....DING DING DING.....WE HAVE A WINNER!!teamrude wrote:NO exact LSA will always be best even on same size and brand motor due to different needs or usage.
Actually, size, brand, needs have very little to do with LSA.teamrude wrote:... NO exact LSA will always be best even on same size and brand motor due to different needs or usage.
I have to agree with this statement.bigjoe1 wrote:Here is the way I see it-- The better the head, the more it will like wide centers. the WEAKER the head, the more it will want tighter centers-- It works this way on every engine I have ever seen
JOWE SHERMAN RACING ENGINES
And:In general, a restrictive motor (defined as a limited flow capability in comparison to the displaced cylinder volume and very high port velocities) do not require early exhaust valve activity. Therefor LSA will trend narrower. The real answer will be driven by E/I system relationships.
Any chance we can get an explanation on why tighter lobe centres benefit the weaker/flow limited headed engine?Here is the way I see it-- The better the head, the more it will like wide centers. the WEAKER the head, the more it will want tighter centers-- It works this way on every engine I have ever seen
Because your typical build uses conventional heads.bigjoe1 wrote:I have been building engines for 60 years now, and every time I try the wider centers , the engine does not produce like I expected. I do not know exactly why, and I can not explain it, but this is what I have seen in hundreds of engines
JOE SHERMAN RACING
Tom Walker wrote: ↑Mon Jan 01, 2018 7:19 pm I just read through the whole thing also. Interesting too, that the thread has died twice for years only to return to life.
