Lobe separation question
kwilliams
Post by kwilliams » Thu Apr 02, 2009 11:59 am
My SBC 388 let go a few weekends ago and damaged my favorite little Erson solid flat tappet cam I had in it. Money is tight right now and trying to get the motor back in service as soon as I can I found a cheapo cam with a close lift and duration that I had. It's a 257/257 @ .050 .553/.561 lift on a 102LS, my Erson was similar to this but was on a 106. Will the 102 vs 106 LS hurt performance?
The motor is a 388 with pro action 210cc aluminum heads, super victor intake, E85 fuel, 12.75 compression, 3000 pound car, 5500 stall, 4.56 gears, 1/8th mile car.
Thanks,
Kevin
Wolfplace
Re: Lobe separation question
Post by Wolfplace » Thu Apr 02, 2009 12:23 pm
kwilliams wrote:My SBC 388 let go a few weekends ago and damaged my favorite little Erson solid flat tappet cam I had in it. Money is tight right now and trying to get the motor back in service as soon as I can I found a cheapo cam with a close lift and duration that I had. It's a 257/257 @ .050 .553/.561 lift on a 102LS, my Erson was similar to this but was on a 106. Will the 102 vs 106 LS hurt performance?
Thanks,
Kevin
I think so but it might surprise you,, I would try it if you have it as I have found there are many times these engine do not read the same magazines we do,, :lol:
Watch the p/v clearance with the tight LSA
Mike
Lewis Racing Engines
4axis CNC block machining
A tour of my shop
The Dyno
And a few pics of the gang
John Wayne
CamKing
Post by CamKing » Thu Apr 02, 2009 12:44 pm
Are you sure the LSA is 102, or is the Intake Centerline 102?
Not too many cams are ground on 102 LSA.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
kwilliams
Post by kwilliams » Thu Apr 02, 2009 12:52 pm
I just looked at it again to be sure and it says it's a 102 lobe separation. The notes say it's for a IMCA modified class or light stock car with 12:1 compression 4000-7100 rpm.
trmnatr
Post by trmnatr » Thu Apr 02, 2009 3:01 pm
That 102 may be a little too tight in my opinion
If you have it try it but back the timing back a few degree as that cam should make more cylinder pressure than the old one and it may or may not push you into detonation
I see you have E85 so there should be no issues but............ Be carefull and try it
andyf
Post by andyf » Thu Apr 02, 2009 3:38 pm
The answer is 107.
Andy F.
AR Engineering
F-BIRD'88
Post by F-BIRD'88 » Thu Apr 02, 2009 6:20 pm
How cheap is cheap? You can buy a generic oval track Elgin E1090P cam for $62 +shipping from CP.
randy331
Post by randy331 » Fri Apr 03, 2009 12:25 am
trmnatr wrote: If you have it try it but back the timing back a few degree as that cam should make more cylinder pressure than the old one and it may or may not push you into detonation
Why would you assume cylinder pressure will be higher with this cam,vs his old one?
Let me guess dynamic compression?? :roll:
Stan Weiss
Post by Stan Weiss » Fri Apr 03, 2009 12:55 am
So which cam will have higher Cranking Compression? :?
