Yep!!! Nice!cspeier wrote:You can make them big as hell also!
SBC Pro Action 14 degree heads
- af2
Re: SBC Pro Action 14 degree heads
GURU is only a name.
Can you actually run that or is it a prototype?cspeier wrote:You can make them big as hell also!
Has Anything You've Done Made Your Life Better?
af2 wrote:Who said only one intake fits?levisnteeshirt wrote:i wouldn't want a set of heads that only one intake fits
I'll make my own as I have before.
i'm just saying ,, i wouldn't want the RHS intake ,, i'd fix a 18 degree to work ,, or something like that ,,,
rookie wrote:Can you actually run that or is it a prototype?cspeier wrote:You can make them big as hell also!
It just ran 195+ in A/ND. It's real..
I wasn't sure if the epoxy would hold up, is that Z Spar 788 (aka Green Death)?
I was told it was toxic when porting and that was where the name came from.cspeier wrote:Yes Z-Spar.
Never heard it called Green Death however.
I take it the iron head has more material than the aluminum, if not, then why is the iron head better or are there "rules" for the A/ND cars that stipulate iron heads only?cspeier wrote:You can make them big as hell also!
Those ports have some SERIOUS volume, and I see the outside walll is into the intake bolt holes, that's nuts! Just how big is the MCSA?
How many cubes did the 195+ A/ND car have?
I have seen a set of aluminum heads and spider intake on eBay for years. They haven't been back on for a while, so I don't know if they actually sold or not, but the guy was asking around $5K IIRC.
Thanks,
Cole
A/ND is a iron head and zommie headers, PG, injected, only class.colebalster wrote:I take it the iron head has more material than the aluminum, if not, then why is the iron head better or are there "rules" for the A/ND cars that stipulate iron heads only?cspeier wrote:You can make them big as hell also!
Thanks,
Cole
The min CSA is 3.22in² at the throat
The engine is 380cid.
BTW, Meaux is the A/ND, iron, God.. I just got lucky.
PS. Here is the iron 23º on the SWJF car that dominated this year. Non-Raised runner.
wonder if a SB2 style head bolt , or some way to get the head bolt out of the way between the rockers , and just move the stud inline with the pushrod and valve ,, if that would workcspeier wrote:rookie wrote:Can you actually run that or is it a prototype?cspeier wrote:You can make them big as hell also!
i wonder if a shoulder could be cut from the underneath , and place a bolt there for that head bolt ,, allen type , make a tool to get at it , ,, then you could put the intake stud where you wanted ,,, looks like a stud girdle could be used then ,,, with a regular style rocker ,,, might be alot just to get rid of shaft rockers , ,, it does look like a offset shaft rocker for this would be under alot of strain from being so offset
if you had it cast with a counter sunk hole ,, for an allen head bolt , then a plug in the port floor , then a hole in the top just big enough to extend a long reach allen head down to the bolt head ,, ,, thinking out loud ,,, sorry ,,
Is there a reason that RHS no longer make the 14 degree in aluminum ? Seem like a very good head, unreal work too chad
Thanks! All 150 hours of it!Conan wrote:Is there a reason that RHS no longer make the 14 degree in aluminum ? Seem like a very good head, unreal work too chad
They do have an aluminum core box. I have one, new RHS casting. The last I heard is they still didn't have a place to cast it.
Chad, Have u ever used port intruders?
