Cleaning carbon from piston tops - any homebrew remedies?
- New Member
- mike ramirez racing
X2 on GM top engine cleaner. However its getting harder to get that stuff. I just used some on my pistons on my saturn. Let it sit over night and stuff wipes off with a rag in the morning.
I've also used purple power or Castrol super clean in my wash basin and hot water. Cleans parts nicely. I let stuff sit for a couple of hours and scrub away.
Joe Sherman is my hero.
The first really high cranking pressure engine i slapped together got the full treatment of sharp edge removal...The pistons had carbon on the tops, but the rest of the piston was really clean..
non chemical
Frown if you want to, I went to the river and gathered 5 gallons of sand that was being blown across the top of the river banks..very fine sand
I taped my pistons and bagged the rods and more tape then with a siphon feed sand blaster(the 18$ cheap one) i blasted the tops of the pistons..It was slow due to the fine sand, maybe 1 minute or 1.5 minutes per piston
Then washed them off in the bath tub, hot water and dry....
To clean small parts like plugs and carbs i now use hot water and baking soda...
non chemical
I think we can all agree bead blasting the pistons would be the best. He was looking for something easier. Not everybody has access to a bead blaster or can go out and buy one. Plus you have to make sure you tape the skirts and pin area well and after which you need to wash the parts again to get rid of the excess sand/glass beads.
Its main ingredient is sodium hydroxide.
Sodium Hydroxide (NaOH) is lye, also sometimes incorrectly called caustic soda. It is a VERY strong base. Strong bases attack aluminum. The interaction of aluminum and NaOH produces hydrogen gas. NaOH can cut the anodizing right off aluminum. It will make a polished surface cloudy and can lead to further degradation of the aluminum.Some common cleaners contain Lye, which will attack Aluminum
-Gary Labrum
Wilder, ID
"faster, Faster, FASTER until the Thrill of SPEED overcomes the FEAR of DEATH!"
Wilder, ID
Just to let you all know the result of using Lye (Sodium Hydroxide) was disasterous.....I was given a sample and used it on an old piston.
When I dropped the piston into the solution it bubbled and foamed like mad. It does strip the carbon off, but then it turns the piston black. Once it dried, the area dipped changed to a dark charcoal grey which looks permanent to me.
The whole process took about 20 minutes.
