I've just dipped a piston in sodium bicarbonate (baking soda) for the past two days and while it is slowly removing the carbon build up, I'd like to think there's a quicker solution.....does anybody have a homebrew mix I can use to remove the carbon buildup?
Let's just say I've got five sets of pistons to do....so was hoping for some miracle concoction to limit the amount of elbow grease I'd have to exert....any other ideas? Is there a mild acid out there which is stronger than the bicarb but won't destroy the pistons if I leave them to soak?
Formula 88. It's available at Home Depot in most areas, or Advance Auto Parts. Soak over night, and use a soft aluminum brush, they will look like this (these are 89k mile piston running rich for boost).
Before and after, pistons/rods from same engine...
Wide Open Throttle Technologies
Pompano Beach, FL
John@m20guru.com
The only stronger chemical that I can think of is carb-dip, don't know if you can still buy that stuff off the shelf but it will turn the carbon into mush that just easily wipes off.
I found an outfit that makes a floor cleaning product with the ethylene glycol monobutyl ether as an ingredient so I rang to order some....however, they recommended using another of their prooducts which is an oven cleaner. Its main ingredient is sodium hydroxide.
Has anybody used a product with this as part of the mix before? I don't particularly want to be a guinea pig here....
