No like all waves it will move both ways. The negative pressure wave will run back up the trough (exhaust pipe) The original pressure pulse will move out into the larger body. The best analogy of this effect is the example I gave of two different size ropes tied together. If you do that experiment you will see two wave fronts moving away from the knot junction, one moves on down in the original direction and a second reflected wave goes back up the smaller rope toward the point of origin.What I'm asking is, the negative reflection..wouldnt that only be present at the exact spot of the size change, and not extend or travel back up the smaller tube? Seems that if gas temperature were removed as a factor (for discussion anyway) that the "depression" would be extremely localized, and very difficult to harness.. How far out am i now?
Exhausted:
I have considered doing the same thing in the past, sort of a stepped header with the first tube gently flaring out to the normal header tube size.
Some of the motor cycles are using tapered headers now and I wonder if that is the reason (increasing flow velocity). They have been discribed as doing it to maintain flow velocity as the boundary layer builds up inside the tube as it moves away from the exhaust port.
Are you willing to discuss approximately how long that smaller diameter section can/should be before it begins to have negative effects due to is internal drag?
Larry
