flat tappet hydro lifters [SBC drag race engine]
Dragsinger
Post by Dragsinger »
without going to the $700.00 plus composite base lifters-----------------
what flat tappet hydo lifter is on the marked that will run to about 7100 - 7200 RPM? The cam and valve train will be proper for the application.
Let me hear about your specific success.
Thanks
Larry Woodfin
CamKing
Post by CamKing »
I think Crower has a hydraulic lifter that'll work.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
3V Performance
Vendor
Post by 3V Performance »
Also check with Cliff @ Sherman Racing, Donaldsonville LA
3V Performance
" ENGINES WITH AN ATTITUDE "
980-222-7230
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 »
The lifters have almost nothing to do with how high the cam will go--- I have used everybodys lifters and they will rev to 7800 RPM without any problems-- ITs all in the cam design
JOE SHERMAN RACING
F-BIRD'88
Post by F-BIRD'88 »
bigjoe1 wrote:The lifters have almost nothing to do with how high the cam will go--- I have used everybodys lifters and they will rev to 7800 RPM without any problems-- ITs all in the cam design
JOE SHERMAN RACING
Big Joe Whose hyd FT cam lobes have you found work best for you?
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 »
I never use them any more, but the Isky 304 Mega--256 at 050- would rev right up there-77-7800-- I am sure that Comp has some that would do it too-
JOE SHERMAN RACING
Dragsinger
just for discussion purposes, these lobes were recommended by Chris Padgit at Comp Cams. They can be run with hydro lifters @ zero lash or with solids @ .004 - .006 lash
intake lobe : #6216 -
lobe lift = .340
@ .006 = 303
@ .050 = 256
exhaust lobe: #6218
lobe lift = .340
@ .006 = 311
@ .050 = 264
This is for a relatively mild, foot brake, bracket engine [350 ci] By my request, these are low lift, fast ramp lobes
bigjoe1
Show Guest
Show Guest
Post by bigjoe1 »
What a coinsidence, they are very much like the old Isky I liked so much--- VERY CLOSE< in fact
JOE SHERMAN RACING
Lasher...
Post by Lasher... »
Back in 74-77 we used the old school Isky 505 lift 310* duration hyd cam in a 383 Mopar with the Isky 2 hole hyd lifters.It would spin 7100 with zero problems all day long.
levisnteeshirt
Re: flat tappet hydro lifters [SBC drag race engine]
Post by levisnteeshirt »
I put together a 383 sbc for a friend , dirt track , long straights , not so tight corners , 120lb valve spring rule ,, I had him buy the isky 304 cam ,, it sounds great , 13-1 motor ,, I figure most guys are gonna pic a ultra aggressive solid ,, I think this motor will pull them hard on the long straights , we'll see
BigBro74
Post by BigBro74 »
My experience with Isky Hyd. flat tappets goes right along with what BigJoe says......
BigBro74
Post by BigBro74 »
levisnteeshirt wrote:I put together a 383 sbc for a friend , dirt track , long straights , not so tight corners , 120lb valve spring rule ,, I had him buy the isky 304 cam ,, it sounds great , 13-1 motor ,, I figure most guys are gonna pic a ultra aggressive solid ,, I think this motor will pull them hard on the long straights , we'll see
not meanin' to hijack, but is This one a 2BBl or 4bbl?
sounds fun. :) Jason
levisnteeshirt
4777 650, any dual plane intake , 120 lb spring , 3400 lbs ,and go ,,, , i'm hoping everybody else picks out a cam that's gonna wad up the weak springs ,, this guy likes gear too ,, its got a 630 gear now ,, gonna be interesting ,, I have a solid cam here if it doesn't work ,, he was low on money of course , so It looked like this was a good path for him
levisnteeshirt
1 in spacer allowed too, i opened his rpm ag up to a 1206, ported the plenum, new class, should be fun
BigBro74
Post by BigBro74 »
valvespring seat load rule. That's not one you see all the time. smooth cam for sure should work nice. That intake with a spacer should be pretty good too. Is this going in a modified type chassis or more like a ss class?
J
