Page 1 of 3
Cylinder Head Battle !
Posted: Wed Dec 24, 2008 11:26 am
by tod85
A Cylinder head battle has recently occured on a mild street/strip bracket motor..... whats your prediction on the power of each? Here is the set-up and the 3 participants.
395 sbc
4.04" bore x 3.85" stroke
Weiand Team G intake
Hyd roller cam .544/.554 w 1.6's - 230/236 @ .050" - 112 lsa
approx 10-1 cr
1 3/4" headers
The Competitors:
1) Camel Back heads with a competition port job done by Mike Stark of CFM performance. 2.02/1.60 - 62 cc chamber
2) Off the shelf Dart Pro-1 Platinum 200cc aluminum cylinder heads - 65 cc - ($ 1460 cost)
3) Off the shelf AFR 195 Eliminator aluminum cylinder heads (street port, not the competition) - 65 cc - ($ 1485 cost)
Who wins ? How much HP of each ?
Posted: Wed Dec 24, 2008 11:42 am
by randy331
That's certainly an interesting test.
Do you already have dyno results?
I'd say it would be hard to get a camel hump heads to out power either of the others, but the fact he stayed with a 2.02" valve is a good sign.
Did the compression stay the same for all the heads?
Randy
Posted: Wed Dec 24, 2008 11:50 am
by tod85
Yes, I have the dyno graph. It is interesting.
Yes, CR was the same.... actually a hair higher with the camel backs due to 62 cc chamber..... other two were 65 cc.
No other changes were done to the motors, same dyno, same day.... each set was tuned for optimum power (timing/jetting)
All dyno results were corrected for fairness.
Posted: Wed Dec 24, 2008 11:57 am
by tod85
The guy who did this test has no connection or particular love for any of the cylinder heads, he was just trying to figure out which one would work best on his motor and the dyno operator was described by him as "Swiss" as in neutral.
He's pretty much a no-nonsense racer who is a straight shooter....
Posted: Wed Dec 24, 2008 12:41 pm
by Ron Miller
tod85 wrote:Yes, I have the dyno graph. It is interesting.
Are you going to post the results ? I would like to see this as well.
Posted: Wed Dec 24, 2008 12:51 pm
by want-a-be
I wouldn't be surprised if the old double humps held their own. Post the results please. would love to check em out.
Don
Re: Cylinder Head Battle !
Posted: Wed Dec 24, 2008 12:53 pm
by ou812
tod85 wrote:A Cylinder head battle has recently occured on a mild street/strip bracket motor..... whats your prediction on the power of each? Here is the set-up and the 3 participants.
395 sbc
approx 10-1 cr
1 3/4" headers
The Competitors:
1) Camelback = 505HP
2) Dart pro's = 500HP
3) AFR Elimin. = 530HP
Just a guess, as the info provided is slim pickin's... :D
There, now post the results....pleeeeeeeze 8)
Brian
Posted: Wed Dec 24, 2008 12:59 pm
by tod85
Alright, give me a minute or two.
Posted: Wed Dec 24, 2008 1:05 pm
by tod85
The below color codes are:
Green: Baseline with camel back cylinder heads and a very, very old solid flat tappet grind back from the 60's or 70's (230/230 area) (Goes to show you how far they've come in cam technology and how these new grinds really help make some power)
The Camel Backs had previously received a competition port job by Mike Stark @ CFM performance and had 2.02/1.60 valves.
Grey: Camel back heads 62 cc chamber- with Hyd roller cam 230/236
Blue: Dart Pro-1 Platinum 200 cc aluminum cylinder heads 65 cc chamber(Cost $ 1460)
Pink: AFR 195 "street" port aluminum cylinder heads 65 cc chamber (Cost $ 1485) (These are not the competition ported AFR cylinder heads)
Conclusion: Considering those old Camel Backs are decades old, they held their own against the Dart Pro-1 Platinums (Good job Mr. Stark and CFM performance)
The AFR's did very well...... and its reported that the competition eliminators would have made another 30 HP on top of the 490ish they show here.
Posted: Wed Dec 24, 2008 1:06 pm
by ou812
tod85 wrote:Alright, give me a minute or two.
:D :D :D :D :D :D :D :D
Posted: Wed Dec 24, 2008 1:37 pm
by B20Paul
That's not really a fair comparison. All else being equal, iron heads are going to make more power at the same compression.
Posted: Wed Dec 24, 2008 1:51 pm
by tod85
B20Paul wrote:That's not really a fair comparison. All else being equal, iron heads are going to make more power at the same compression.
Interesting input.....
You must be referring to the camelbacks because the Darts & AFR's are both aluminum.
But, should I recast the camel back for you ? Not sure how to solve your problem with them....
by ou812
But the alum heads should have better chambers and ex ports...
Posted: Wed Dec 24, 2008 1:57 pm
by B20Paul
How much extra heat is lost to the cooling system when comparing iron to aluminium heads? That heat loss is why aluminium heads can run higher compression all else being equal.
Posted: Wed Dec 24, 2008 1:58 pm
by tod85
As a note, I thought the camelbacks ported by CFM performance did GREAT !!! Thats a cylinder head close to 50 years old competing quite nicely with the Dart cylinder heads....... impressive in my opinion.
