This question has the makings of another "Torque Vs. Horsepower" debate, guys!
Nonetheless, here's a couple of thought starters:
o Friction relates to the normal (right angles to the surfaces) force and the coefficient of friction between the surfaces. That's why it's harder to drag a diesel block across the shop floor than an aluminum LS Chev one. Clearly, when you're transmitting more torque through a gear pair, etc., there is a greater contact force, thus more friction. As the RPM rises, this translates to more power loss.
o This is also why with your car (to simplify, lets say with a manual tranny) on a chassis dyno, you could take the plugs out and rotate the engine, driveline and inertia roller with a breaker bar, even though the same components would absorb hundreds of horsepower at high loads and RPM.
o A really precise analysis of
all the drivetrain losses would likely reveal a range of characteristic variables Vs. speed and load ranging from fixed, to direct percentages with either and/or both RPM and load, to ones increasing at some power over one (e.g., squared) Consider a 4,000 RPM stall torque converter with lock up. At 1,000 RPM, it absorbs 100% of the engine's power. Between there and lock up, it's a variable, dependent on RPM and engine torque. After lock up, it becomes a much smaller factor..
o Obviously, just as on an engine dyno, everything we can do to standardize the test conditions [tire pressures, actual (test-specific?) tires, hold-down strap tension and angles, all lubricant temps, atmospheric correction factors, etc., etc.] will help with consistency, but with many more factors in play than for an engine dyno, the opportunities for variations will remain higher.
o Bottom line, an approximate percentage loss is the best when can do for a general case, and unless dyno racing is the sole object, it serves the purpose of showing proportional changes as the tuning process proceeds.
