Big block chevy oval port intake and carb reccomendation
jobes
Post by jobes » Sat Nov 15, 2008 4:07 pm
Engine is 4.31 bore with 4.0 inch stroke,Ultradyne roller 270-280 108 lobe separation.12.5 compression,6.135 rod.Using 049 iron oval ports with 2.19-1.72 valves.DRAG RACE only,What would be a good intake and carb to run.Thanks for inputs
Alan Roehrich
Post by Alan Roehrich » Sat Nov 15, 2008 5:14 pm
A Holley 300-5 intake and probably a Quick Fuel 950 4150 style carb, with a 1" super sucker style spacer between them. At least that'd be a good place to start.
Abbottracingheads
Post by Abbottracingheads » Sat Nov 15, 2008 7:21 pm
The Edelbrock Victor oval port and 1050 Dominator will out run the rest.
m.maxwell
Post by m.maxwell » Mon Nov 17, 2008 12:22 am
I'd run a Dart any day but it does require extensive porting. A 4150 would likely be adequate for your dispacement. Dart make's both oval port manifolds for either a Dominator or a 4150 but they would both require porting.
when in doubt read the directions
DOTracer
Post by DOTracer » Tue Nov 18, 2008 8:04 am
Edelbrock Victor jr intake and a 1000HP 4150 Holley. Dominator wasn't worth anything on my old 461ci combination, plus the low speed drivability was poor with the dominator.
