3.25 stroke- 4.155 bore
I have some stuff layin around I want to use up. I have a set of 6" rod 406 pistons,a 400 block and a 327 crank. To make this work, Id have to use a set of 6.250 long rods. Does anyone see a drawback in such a long rod short stroke combination like this? Eagle has the 6.260 long SIR rod for like $250. Lookin to use it for a IMCA mod application not more then 500 hp. Would this combo really need some special ground cam? Thanx Brad
Re: 3.25 stroke- 4.155 bore
Keith Black has a flat top piston for use with a 6" rod2xmod wrote:I have some stuff layin around I want to use up. I have a set of 6" rod 406 pistons,a 400 block and a 327 crank. To make this work, Id have to use a set of 6.250 long rods. Does anyone see a drawback in such a long rod short stroke combination like this? Eagle has the 6.260 long SIR rod for like $250. Lookin to use it for a IMCA mod application not more then 500 hp. Would this combo really need some special ground cam? Thanx Brad
I know a guy who ran 7.20's with this combo in a 2400 pound race weight chasis. Twin dominators, sheet metal intake
What would be best is to get a block with 283/327 mains or 350 mains and get a crank with 350 mains or 283/327 mains
One time i saw a Bryant 3.26" stroke crank on Racingjunk for $550, it had 283 mains and Honda rod journals
If you've got a really hard tire, and have trouble hooking it up, this would be a good combo for you.
PS, yes you'll need a custom cam.
Mike Jones
Jones Cam Designs
Denver, NC
jonescams@bellsouth.net
http://www.jonescams.com
(704)489-2449
Jones Cam Designs
Denver, NC
(704)489-2449
I would think on a dry slick track this would be great.2xmod wrote:I have some stuff layin around I want to use up. I have a set of 6" rod 406 pistons,a 400 block and a 327 crank. To make this work, Id have to use a set of 6.250 long rods. Does anyone see a drawback in such a long rod short stroke combination like this? Eagle has the 6.260 long SIR rod for like $250. Lookin to use it for a IMCA mod application not more then 500 hp. Would this combo really need some special ground cam? Thanx Brad
On a tacky track you would really have to put a gear in it to make it work well.
- New Member
This is almost the same as the build that i am doing 4.155 x 3.335. It is what i have so i am going to use it and see what i can get out of it. Keep us posted with the results as will i.
www.automotiverestorations.com
Very funny Scotty; now beam down my clothes
I am not speeding I am qualifying.
This is the rebel base.
This 4.125"x3.25" has been the hot setup for dirt guys limited to 360" In fact, recent requests from some dirt track guys have us digging through our crank pile. We turned up a couple of large-journal 3.25" 327" forged cranks which are now being cleaned and turned. What are you guys paying for a good stock crank ready to run?
thnx, jack vines
thnx, jack vines
- New Member
I picked up my LA billet crank for $400. 3.335 stroke. I know some people dont like ebay but if you shop around and do your research you can get some really good deals
Check out ebay item number> 220289673049 and 220289699121
