Which Aluminium grade for Main caps?
Which grade is preffered, I haven't had a change to research it at all. 6061 or 7075?
Thanks
AL...
Thanks
AL...
Isn't sufficient strength to keep the crank in the engine at max rpm/power Job One? Aluminum caps on an iron block seem to me to be the weak link.la360 wrote:Small block Chrysler , factory block. Aluminium absorbs bottom end harmonics better than steel????
AL...
I'm not familiar with "botom end harmonics". Please elaborate.
I think this begs the question Why engine builder's fit aluminium caps to Blocks , over a set of 4340 steel caps? It is obviously more common in the Mopar engine building circles than anywhere else. The common reason given for doing this is that Aluminium absorbs the harmonics/vibrations produced during the engine's operation better than steel or cast iron. I think alot of us have just taken this as gospel, myself included , without really understanding the ins and outs of the whole situation.
Alot of guys running factory Mopar B and RB blocks, will run the Aluminium caps as apposed the factory caps, which crack, or a steel cap, because the common thinking is the block lives longer in a highly stressed situation, and I guess this is backed up by the number of varying Brands of aluminium caps available for them currently. I was following the same thinking with my small block, I was curious to see what affects and possible benefits the Aluminium caps may produce.
Any Thoughts?
AL...
Any Thoughts?
AL...
Maybe it's the Coriolis effect of running a North American designed engine below the equator.la360 wrote:I think this begs the question Why engine builder's fit aluminium caps to Blocks , over a set of 4340 steel caps? It is obviously more common in the Mopar engine building circles than anywhere else. The common reason given for doing this is that Aluminium absorbs the harmonics/vibrations produced during the engine's operation better than steel or cast iron. I think alot of us have just taken this as gospel, myself included , without really understanding the ins and outs of the whole situation.
Any Thoughts?
AL...
Thoughts:
With only a couple thou main bearing clearance, distortion of the main bores needs to be minimized as much as possible iln order to keep from wiping out bearings and then the crank.
If the blocks are weak enough to move around and crack iron caps, aluminum caps will allow things to move around more, but to me that means wiping out bearings, and sooner or later running over you own crank.
One of the cap's duties is to stiffen up the lower end of the block. 4-bolt, and cross bolting and girdles or structural oil pans all lead to this.
I was not familiar with aluminum cap conversions for Mopars, and still don't see the benefits. Aluminum has a shorter fatigue life than iron or steel, so if they "absorb(s) the harmonics/vibrations produced during the engine's operation better than steel or cast iron" they should have a very short lifespan.
FWIW, cast iron is about the BEST metal for absorbing vibrations. It is used extensively for machine tool bases just for that reason.
Someone else might be able to shed more light on this.
My $.02
Shawn- The motor I did was an Ex-Pro Stock Truck block. It runs 930 HP @ 9600 RPM. I was surprised it would survive with the aluminum caps. The Main Housing bores measured .001 tight from the tight side of the factory spec. The clearances where on the tight side too. But has survived the 1/4 mile for 3 years.
