Alan Roehrich
PostPosted: Sun Jul 27, 2008 6:41 pm Post subject: Reply with quote
I'd agree, it is next to impossible to get a 49cc dome into MOST 105cc chambers. Especially if you have around 0.042" total deck clearance, and around 0.006" or so bore clearance. It can be done, but it generally means that you or some one has done some serious measuring and massaging.
IF you have an honest 14:1, and are running 110 octane fuel, then you are detonating, even if you DON'T have an oil control problem. Unless you have 280 degrees duration on a 108 or tighter lobe separation angle, and are running less than 36 degrees timing.
If it is indeed detonating, you'll NEVER keep the rings sealed. You could put rebuilder oil rings in it and it would oil soon enough.
Now you need to take a NEW compression ring and put it in the top and second grooves, and see how thick a feeler gauge you can get in with it, DO NOT try to cram it in. I'd be surprised if the grooves, or at least the top one, hasn't opened up. If it has, it won't seal up.
If I can run a 427 with the oil ring expander 0.040" smaller than the bore size is supposed to require, with no vacuum pump, no dry sump, and no crank case evac, then you shouldn't have any trouble doing it. My 427 has so little ring tension that the fully assembled engine, without the valves adjusted, will rotate with only 10 foot pounds of torque, even including the break away torque to start it turning. My 427 makes over 580HP, with a flat tappet .520 lift cam, and it goes through the lights at 8000 RPM on a good pass in good air.
Alan, Thank you for contributing, I certainly need the help. I put a new ring in top groove, I can get a .0015 in and .002 won't go. In the second groove .002 will go. I have extra pistons that are brand new and the results are the same. It doesn't seem like the grooves have opened up. This cam is 270/280 with 108 separation and I do run the timing at 36-37. SO, either I'm very lucky or my burette is way off and I really only have 12:1. Until I confirm my measurements, I will hold off on any engine assembly. What rings would you suggest? My rotating assembly is pretty heavy, with old Manley rods and pistons.
MaxFlow
PostPosted: Sun Jul 27, 2008 7:25 pm Post subject:
Alan brought up a point that gets overlooked so many times. Detonation and ring seal don't mix. 107-112 track gas and 14.1 don't mix especially with big domes.
That flamefront is atrocious. Between oiling, detonation, carburetion, ect...that engine is down big time. It needs to come completely apart anyway for rings and while its down message those domes up, put some decent gas in there......git er tuned up.
Thank you for jumping in. I've shown these pistons to many people that are supposed to be in the know and no one has been critical of the way the flame pattern looks. I have always thought it looked bad, both in color and pattern. I hope I can straighten this thing out with everyones help. Tell me what the flame front should look like. I don't really want to have to buy better gas, so my first chore will be to verify my measurements.
