Hurrican vs. Victor Jr. vs. GM Intake
xtreme872
Post by xtreme872 » Fri Jun 27, 2008 12:15 pm
I am purchasing a setof dart iron eagle platinum 215 heads. My old intake was the professional products intake for vortec heads. I have to buy a new one just wondering is the victor jr. better or is the hurricane ok. Or how about one of GM'S INtake
jeffmckc
Post by jeffmckc » Fri Jun 27, 2008 1:09 pm
I have had good luck with both the Hurricane and Super Hurricane intakes after some port work like with any intake
2007 HotRod Drag Week Winner SB/NA
2012 HotRod Drag Week Winner SS SB/NA
Fastest/Quickest Small Block N/A
Stock Suspension Car on Drag Week since 2007
9.67@ 139 with a 1.42 60' thru the Mufflers Dot tires
Thanks RFD Heads and Intakes
jmarkaudio
Post by jmarkaudio » Fri Jun 27, 2008 2:11 pm
I like the Victor Jr for milder small blocks, Super Victor for large or more radical combo's. How about the engine specs and intended use?
Mark Whitener
____
MELWAY
Post by MELWAY » Fri Jun 27, 2008 5:32 pm
A GM bowtie will kill all of those...
airflowdevelop
Post by airflowdevelop » Sat Jun 28, 2008 9:37 pm
For the money I have not found anything that will touch the motown or GM bowtie intake. on a 358 sportsman motor, the super vic takes about 6 hours more to almost make the power of a properly setup motown.
Dennis
AA Performance
Post by AA Performance » Sat Jun 28, 2008 9:50 pm
What's involved in properly setting up the Motown & what RPM are we talking about?
sanfordandson
Post by sanfordandson » Sat Jun 28, 2008 10:35 pm
i agree with the motown. works well with a 215 head.
airflowdevelop
Post by airflowdevelop » Sat Jun 28, 2008 10:39 pm
Power in at 7600, rev to 8000. I adjust the elephant ears for runner length. get the radius right on the carb flange to bottom of plenum. Adjust CSA and taper. port match to cylinder head and bolt it on.
no welding, no wild spacers...very easy to work on. Total Job cost $375.00. I have had well over a grand in super-vics pre-bowtie/motown and they don't touch the new stuff.
trmnatr
Post by trmnatr » Sun Jun 29, 2008 5:13 pm
airflowdevelop wrote:Power in at 7600, rev to 8000. I adjust the elephant ears for runner length. get the radius right on the carb flange to bottom of plenum. Adjust CSA and taper. port match to cylinder head and bolt it on.
I have had good luck with Dart single plane intakes and Edelbrock Victor E intakes on SB chevy engines using Dart 215 heads
I have also used Professional Products and had descent results too on the track
A Atwood
Post by A Atwood » Sun Jun 29, 2008 10:19 pm
Isn't the pro products a Chinese unit?
ARN
www.atwoodperformance.com
z28freak84
Post by z28freak84 » Sun Jun 29, 2008 11:47 pm
A Atwood wrote:Isn't the pro products a Chinese unit?
ARN
Yes it is.
1985 original SILVER Metallic Camaro IROC-Z
1995 ZX-11 NINJA_ Muzzy exhaust and Polished EVERYTHING!
jeffmckc
Post by jeffmckc » Mon Jun 30, 2008 7:42 am
It is designed in USA built in China. Very good line of sight, Tall plenum
xtreme872
Post by xtreme872 » Mon Jun 30, 2008 11:58 am
Truck pull application. Cam should peak at about 5600-6000. I just worry about giving up too much midrange power with a big intake. 383c.i. engine dart 215 platinum heads
