That is an absolutely true statement. It can be confirmed by any combustion engineering textbook.A mixture that is very close to stoich (for that particular fuel) will require the minimum amount of timing (and spark energy).
After a review of Taylors work (as well as Heywood) the texts still indicate that mixtures just slightly rich of stoich are most prone to detonate. The fuel ratio quoted by Taylor and Heywood and several NACA papers are a fuel ratio of .071, which converts to an A/F ratio of 14.08. While that is the ratio most prone to detonation, it is not the ratio for best power.Unless something’s changed since Taylor’s MIT research prior to and during WWII the A/F (with gasoline) that has the highest combustion velocity hence requires the least spark advance is very near .87λ (12.8/1).
The A/F that requires the least voltage to ignite is very rich, on the order of 10/1.
Only if the engine is very cold and the fuel won't evaporate. Ignition is a function of energy, not just voltage. Excess fuel increases the energy requirement.
The spark duration of CD ignitions is very, very short. This can cause misfires if the mixture in the spark plug gap is not suitable. Which is why folks like Bosch have abandoned CD ignition systems as being obsolete.The voltage measurements are reported in 30’s era research so I doubt if there was CD ignition involved.
Just how does anyone know what A/F ratio they are running? An oxygen sensor does not output an A/F ratio; it measures the partial pressue of oxygen and doesn't give a damn about fuel. If we try to use lambda, it must be based on a fuel with a known stoich value. What is that? Does anyone know the stoich value of the fuel they are using?
