Milling a small block intake manifold
hbps1978
Post by hbps1978 » Tue Jul 17, 2018 9:47 pm
Can some of our resident machinists/engine experts help me with this question please. I have milled the deck of my small block Chevy 350 block .030" to raise the pistons within .005" of zero deck height. My cylinder heads are new AFR Eliminator heads that are stock out of the box and have NOT been milled. I have a Chevrolet #10185063 dual plane intake manifold. Can someone tell me how to mill the intake manifold to match the heads now that the deck of the block has been milled. Thanks :?:
Performance is my passion
rfoll
Re: Milling a small block intake manifold
Post by rfoll » Tue Jul 17, 2018 10:24 pm
Before you worry about machining the manifold, set it up and lay out the alignment. You maintop need to do any more than a minor port match.
Post by MadBill » Tue Jul 17, 2018 10:42 pm
(SpeedTalker) Wallace Racing to the rescue: http://www.wallaceracing.com/calc-intake-mill.php
SupStk
Post by SupStk » Tue Jul 17, 2018 10:55 pm
Like mentioned, check port alignment before worrying how much to mill the intake.
If it needs to be cut, check out the link MB provided.
Monty Frerichs
B&M Machine
ProPower engines
Post by ProPower engines » Wed Jul 18, 2018 2:23 am
I never machine the intake unless it is absolutely a must.
Machining the intake face of the heads will allow you to change the intake down the road with little misalignment issues compared to having to cut the intake.
